kbhanuprakash's avatar
Jul 13, 2021
Unable to connect to Internet with additional router with ONT [Optical Network]
Hi,
I am currently owning a Orbi Wifi Mesh Network system RBR50 and would to understand the configurations/settings that i need to enable so that i can plugin orbi wifi mesh to existing router/modem from Genexis.
Please share the configurations or inputs on how to setup wifi mesh network with existing router with ONT.
Thanks,
Bhanu
1 Reply
    Thousands of customers simply connect the WAN (yellow) Orbi port to the ISP modem and use the Orbi, never realizing that there might be "something different" about a modem/router than a modem.  Depending on what IP subnet the Genexis is using, Orbi may set its subnet to 10.0.0.x rather than the typical 192.168.1.x
    Having two routers creates a Double NAT situation which can interfere with specific applications, such as port forwarding, OpenVPN into the router from the internet, and certain internet gaming. https://kb.netgear.com/30186/What-is-Double-NAT If you do none of those things, then it has no effect on you.
    Many users prefer to eliminate Double NAT by either:
    • Putting the ISP device into 'bridge mode' so that the Orbi takes over as the only router, or
    • Putting the Orbi into Access Point (AP) mode so that the ISP device is the only router.
