AdeB's avatar
AdeB
Unable to connect to SIP provider when internet connection re syncs
Hi,
My Orbi system RBK40 keeps dropping its internet connection, and everytime my Gigaset IP phone is then unable to reconnect to the SIP gateway. That is until I reboot the router, then it's fine until the next internet drop. I've tried rebooting and powercycling the phone, tweaking settings, but the only thing that solves it is a reboot of Orbi. Even a manual disconnect and reconnect of the internet doesn't help. There must be some glitch in the routing or UPnP...?
Any ideas? It's driving me nuts!
Thanks
Adrian
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    Is your modem dropping the internet connection and the orbi does not reconnect after the drop or is it just the orbi disconnecting?
    DarrenM
    • AdeB's avatar
      AdeB
      Hi
      It's the Orbi continuously disconnecting - the modem doesn't report any drops
