papanito
Apr 26, 2021Aspirant
Unable to connect via WIFI b ut LAN: Invalid security certificate
As of today I suddenly cannot connect to the internet using WLAN. Browser tells me that the security certificate is invalid The certificate does not match the url I want to browse (in that cas...
papanito
Interestingly if I can accept the risk and go on - e.g. browsing to https://www.routerlogin.net/ I will be presented with this screen telling me This device is blocked by Access Control in the router.
- papanitoApr 26, 2021Aspirant
Model Name Device Name Current Version Status Router RBR50 RBR50 V2.7.2.104 No new firmware version available. Satellite RBS50 Satellite-1 V2.7.2.104 No new firmware version available. - FURRYe38Apr 26, 2021Guru - Experienced User
So did you use access controls to block one of your devices?
Can you get into the RBRs web page with a wired PC?
Is Armor or Circle enabled?
So did you use access controls to block one of your devices?Yes but even when disabled I see the same message. In additiona my notebook is whitelisted.
Can you get into the RBRs web page with a wired PC?Yes as mentioned I can access as long as it's wired. Interestingly also the mobile phones of me and my family did not encounter the issue. But my son with Windows PC had the same issue.
Only circle. But also disabled it without success.
What seemed to help is pressing the reset button on the back of the device - well I thought I do a factory reset so I pressed until it was blinking amber. However, settings were kept so I reconnected my notebook to the WLAN and now it works.
I really would like to understand what was going on, even so I am reliefed it works
- randomousityApr 26, 2021Luminary
Looks like you've somehow ended up with your device being blocked in the access control list (ACL). Could be inadvertant misconfiguration, someone else (another family member?) blocked you, or just a glitch (I've randomly had one or two devices blocked for no apparent reason). Use a different device (or the same one over ethernet, if that works), log on to the Orbi configruation, go to advanced > security > access control, and check for any blocked devices in the ACL, either in the top table (currently connected devices), or the bottom one (blocked devices not currently connected), and then check the box(es) for whichever blocked device(s) you want to allow (one at a time, unfortunately), then click edit, change to "allow," apply the change, and then repeat as necessary.
That should probably resolve your issue.
After making any changes to the RBR or access control list, you may want to reboot the RBR AND any effected devices fully after making changes to the access control list.
randomousity wrote:Looks like you've somehow ended up with your device being blocked in the access control list (ACL). Could be inadvertant misconfiguration, someone else (another family member?) blocked you, or just a glitch (I've randomly had one or two devices blocked for no apparent reason). Use a different device (or the same one over ethernet, if that works), log on to the Orbi configruation, go to advanced > security > access control, and check for any blocked devices in the ACL, either in the top table (currently connected devices), or the bottom one (blocked devices not currently connected), and then check the box(es) for whichever blocked device(s) you want to allow (one at a time, unfortunately), then click edit, change to "allow," apply the change, and then repeat as necessary.
I double checked and my device was NOT blocked and as I am the only one with access nobody else could have blocked it, As mentioned above eben disabling ACL did not solve the problem for me
- FURRYe38Apr 27, 2021Guru - Experienced User
I'd factory reset and setup from scratch. Something in the configuration is not working right.
