papanito
Apr 26, 2021Aspirant
Unable to connect via WIFI b ut LAN: Invalid security certificate
As of today I suddenly cannot connect to the internet using WLAN. Browser tells me that the security certificate is invalid The certificate does not match the url I want to browse (in that cas...
papanito
Interestingly if I can accept the risk and go on - e.g. browsing to https://www.routerlogin.net/ I will be presented with this screen telling me This device is blocked by Access Control in the router.
Apr 26, 2021Guru - Experienced User
So did you use access controls to block one of your devices?
Can you get into the RBRs web page with a wired PC?
Is Armor or Circle enabled?
