papanito
Apr 26, 2021Aspirant
Unable to connect via WIFI b ut LAN: Invalid security certificate
As of today I suddenly cannot connect to the internet using WLAN. Browser tells me that the security certificate is invalid The certificate does not match the url I want to browse (in that cas...
Apr 26, 2021Guru - Experienced User
So did you use access controls to block one of your devices?
Can you get into the RBRs web page with a wired PC?
Is Armor or Circle enabled?
papanito
Yes but even when disabled I see the same message. In additiona my notebook is whitelisted.
Yes as mentioned I can access as long as it's wired. Interestingly also the mobile phones of me and my family did not encounter the issue. But my son with Windows PC had the same issue.
Only circle. But also disabled it without success.
What seemed to help is pressing the reset button on the back of the device - well I thought I do a factory reset so I pressed until it was blinking amber. However, settings were kept so I reconnected my notebook to the WLAN and now it works.
I really would like to understand what was going on, even so I am reliefed it works
