papanito
Apr 26, 2021Aspirant
Unable to connect via WIFI b ut LAN: Invalid security certificate
As of today I suddenly cannot connect to the internet using WLAN. Browser tells me that the security certificate is invalid The certificate does not match the url I want to browse (in that cas...
randomousity
Apr 26, 2021Luminary
Looks like you've somehow ended up with your device being blocked in the access control list (ACL). Could be inadvertant misconfiguration, someone else (another family member?) blocked you, or just a glitch (I've randomly had one or two devices blocked for no apparent reason). Use a different device (or the same one over ethernet, if that works), log on to the Orbi configruation, go to advanced > security > access control, and check for any blocked devices in the ACL, either in the top table (currently connected devices), or the bottom one (blocked devices not currently connected), and then check the box(es) for whichever blocked device(s) you want to allow (one at a time, unfortunately), then click edit, change to "allow," apply the change, and then repeat as necessary.
That should probably resolve your issue.
Apr 26, 2021Guru - Experienced User
After making any changes to the RBR or access control list, you may want to reboot the RBR AND any effected devices fully after making changes to the access control list.
