vadordog
Feb 17, 2018Tutor
Unable to connect Wink Hub 2 to Orbi System
I have been unable to connect Wink Hub 2 to the Orbi RBK43 System, went through many failed attempts with Wink Customer Support and NetGear Customer Support. The Wink Hub 2 see's the Wi-Fi network with a "\x20" out front of the actual network name. Has anyone else had trouble connecting the Wink Hub 2 to the Orbi system? Works if the Wink Hub 2 is plugged into the main router or a satilite via eithernet. Tried powering down the satilites and connecting to only the router, showed same incorrect network name and failed to connect. Have attached screen shot of the network name with "\x20" out front.
Thanks for the help!
- DarrenMSr. NETGEAR Moderator
Nothing else sees the \x20 when connecting to the network?
DarrenM
- kolellaApprenticeAre you sure your SSID doesn't start with a leading "space"?
- vadordogTutor
Resolved: There was a space in front of the network name when logging in with the Wink Hub 2. Thanks for helping with the fix.
