JPFox
May 17, 2020Aspirant
Unable to Connect
I am unable to reconnect my Orbi Mesh router to Modem, I cannot see the orbi in my connections on my phone ? Help !!
May 17, 2020Guru - Experienced User
1. What modem are you connected to?
2. You can try hardwiring into the orbi for setup.
3. Maybe it was a refurb/renewed/used unit? If so, try factory resetting it. Push and hold reset for 7-15 seconds while its powered up to get back to factory.
- JPFoxMay 17, 2020Aspirant
I was finally able to see the Orbi on my phone but it was not connected to the internet, So I Rebooted my Modem again and now I cannot see it Now, So .. I hit the Rest button on the Orbi, Still not able to see the Orbi Network on my phone ?
- plemansMay 17, 2020Guru - Experienced User
have you tried hardwiring into it for ease of setup?
- michaelkenwardMay 18, 2020Guru - Experienced User
Remember that you have to do things in the right order. (See the set up guide.)
- Turn off and unplug modem.
- Turn off router and computers.
- Plug in and turn on modem. Wait 2 minutes for it to connect.
- Turn on the router and wait 2 minutes for it connect.
- Turn on computers and rest of network.
And, as plemans says, try to do things with wired connections rather than over wifi.
