tdeutscher
Dec 30, 2017Aspirant
Unable to download file using Orbi Router
Hi All, While I can browse any website, I am unable to download files of any size when connected to the Orbi Router (RBR50). The message shown is "Network Failure" with any browser i use to try t...
st_shaw
Dec 30, 2017Master
There is no fundamental problem with Orbi downloading files, so it's got to be something about your network setup.
If you can connect to your router and download files from the Internet, it sounds like your modem may also be a router. In that case I suggest you configure Orbi as an access point.
- tdeutscherDec 30, 2017Aspirant
Thank you for the reply. The modem is a Motorola MB8600 and has no router features. I can connect through Orbi to the modem (i.e. login to modem admin or go to the internet). Files just will not download. I used the IOS App to set up Orbi. Orbi is the network so there must be a setting within Orbit that is doing this (I guess). No sites are blocked in the Orbi Settings etc. My other comment is, that when I first set up Orbi i was able to downloand fine (June 2017). About three months ago it stopped. Sidenote, Orbi's Firmware update was set on Automatic, though today when I checked, it indicated no new firmware, yet when I went to Orbi support site, there was a newer firmware than that which as on the machine. Manually updating to that today had no effect. Thanks again.
- st_shawDec 30, 2017Master
This is just a stab in the dark, but try reducing the MTU size. Maybe start with 1300 and work up from thereif it works.
See page 50 of the users manual.
http://www.downloads.netgear.com/files/GDC/RBK50/Orbi_UM_EN.pdf
- tdeutscherJan 08, 2018Aspirant
Thank you. I tried the MTU settings to no avail. The actual message i receive is "Failed - Network Error" when downloading with Chrome for example. I don't understand why with VPN it works, or the modem directly it works, but through ORBI it dies. I have set up and reset up the system but nothing works. All other settings are via default from the Setup.
Any additional thoughts or ideas would be appreciated. Thanks!
