tdeutscher
Dec 30, 2017Aspirant
Unable to download file using Orbi Router
Hi All, While I can browse any website, I am unable to download files of any size when connected to the Orbi Router (RBR50). The message shown is "Network Failure" with any browser i use to try t...
tdeutscher
Thank you for the reply. The modem is a Motorola MB8600 and has no router features. I can connect through Orbi to the modem (i.e. login to modem admin or go to the internet). Files just will not download. I used the IOS App to set up Orbi. Orbi is the network so there must be a setting within Orbit that is doing this (I guess). No sites are blocked in the Orbi Settings etc. My other comment is, that when I first set up Orbi i was able to downloand fine (June 2017). About three months ago it stopped. Sidenote, Orbi's Firmware update was set on Automatic, though today when I checked, it indicated no new firmware, yet when I went to Orbi support site, there was a newer firmware than that which as on the machine. Manually updating to that today had no effect. Thanks again.
st_shaw
Dec 30, 2017Master
This is just a stab in the dark, but try reducing the MTU size. Maybe start with 1300 and work up from thereif it works.
See page 50 of the users manual.
http://www.downloads.netgear.com/files/GDC/RBK50/Orbi_UM_EN.pdf
- tdeutscherJan 08, 2018Aspirant
Thank you. I tried the MTU settings to no avail. The actual message i receive is "Failed - Network Error" when downloading with Chrome for example. I don't understand why with VPN it works, or the modem directly it works, but through ORBI it dies. I have set up and reset up the system but nothing works. All other settings are via default from the Setup.
Any additional thoughts or ideas would be appreciated. Thanks!
