Adwiz
Feb 25, 2021Aspirant
Unable to download from Amazon AWS servers
I have been using an Orbi RBR20 system for the past year. It has downloaded fine from Amazon's AWS servers until today. Now it generates the following error: Secure Connection Failed An error oc...
- Feb 25, 2021
Do you have Armor enabled or anything else proxying your Orbi requests?
CrimpOn
Feb 25, 2021Guru - Experienced User
Can you provide a link to this AWS announcement?
Almost the entire web has switched to SSL (https) connections. One hypothesis might be that if all other web connections work and AWS is the only one that fails, the "something that has changed" is AWS.
This error occurs often enough that internet searches turn up many hits, such as this one:
Adwiz
Unfortunately I don't have the notice from AWS. The tech support rep at WPEngine told me about it, as he believes it's related to the problem. My router is running the latest firmware and has no weird issues like double NAT. Given that the problem just started, it seems logical that the new configuration at AWS is related. But it means no downloads from that service are possible with my Orbi. I can only download by tethering to my phone's cellular data network. With website backups in the hundreds of Mb that's not exactly something I look forward to.
- CrimpOnFeb 25, 2021Guru - Experienced User
Oh, bummer. So none of the recommendations on those web sites were helptul?
No VPN? Browser caches cleared? Change DNS servers? etc.
There appear to be multiple method of doing WPEngine backups. Do they all fail with the same error?
- AdwizFeb 25, 2021Aspirant
There are many ways to backup Wordpress sites, but the ones that involve plugins are very server intensive and can be problematic on busy sites because they are so slow. The ones created by the hosting environment are reliable and add no load to the server. I have a redundant daily server backup system using Blogvault that doesn't use Amazon AWS servers so it can be used until (if) Netgear fixes this issue with the Orbi.
