Adwiz
Feb 25, 2021Aspirant
Unable to download from Amazon AWS servers
I have been using an Orbi RBR20 system for the past year. It has downloaded fine from Amazon's AWS servers until today. Now it generates the following error: Secure Connection Failed An error oc...
- Feb 25, 2021
Do you have Armor enabled or anything else proxying your Orbi requests?
Adwiz
There are many ways to backup Wordpress sites, but the ones that involve plugins are very server intensive and can be problematic on busy sites because they are so slow. The ones created by the hosting environment are reliable and add no load to the server. I have a redundant daily server backup system using Blogvault that doesn't use Amazon AWS servers so it can be used until (if) Netgear fixes this issue with the Orbi.
Mikey94025
Feb 25, 2021Hero
- AdwizFeb 25, 2021AspirantThank you! I checked Armor on the computers and it wasn’t installed so I didn’t think it was an issue. But it was enabled on the router and I hadn’t even thought of that. Disabled it and voila! All good. Thanks so much!
