eye-eye
Aug 14, 2021Aspirant
Unable to get RBR50 to work as router with Draytek 130 modem
Hi I was having problems with DHCP on my BT Smart-hub 6 so I bought a Draytek 130 to act as a modem and use the Orbi as a router. I have upgraded to latest Draytek firmware and confirmed the broad...
Aug 16, 2021Guru - Experienced User
Try powering OFF the modem AND RBR for 1 minute then back ON with the modem then RBR...
Be sure your using good quality LAN cables. CAT6 is recommended.
Contact the ISP and or the modems mfr for additional help and support regarding there product.
