kdbajaj22
Sep 26, 2019Tutor
Unable to login to Corporate Office 365 portal
Hello Everyone, I've been using RBK53 at home since nearly 2 years. It is currently on firmware 2.3.5.30 I have an issue which i have been simply "living with" since the day I got this router wh...
nguser_01
Mar 03, 2020Aspirant
We just ran into the same thing. if you try accessing http://portal.office.com and you are presented with a netgear page, that is the cause of your issues. We were unable to install Office 365 while behind a Netgear router because of this issue. Swapped out to a different router and were able to install without any other changes to the PC or network. Wasted 2 days on this issue to find out it's an issue with the Netgear router intercepting the traffic for this address http://portal.office.com (try it without https).
tomschmidt
Mar 03, 2020Virtuoso
Do you have Armor and/or Circle enabled on your Orbi? If so, they may be causing the issue. I do not have either enabled, and when I navigate to http://portal.office.com it redirects me to https://login.microsoftonline.com/ for login to Microsoft as it should. Using http or https has the same results.
nguser_01 wrote:We just ran into the same thing. if you try accessing http://portal.office.com and you are presented with a netgear page, that is the cause of your issues. We were unable to install Office 365 while behind a Netgear router because of this issue. Swapped out to a different router and were able to install without any other changes to the PC or network. Wasted 2 days on this issue to find out it's an issue with the Netgear router intercepting the traffic for this address http://portal.office.com (try it without https).
- kdbajaj22Mar 07, 2020Tutor
I think I have finally figured it out but I will have to observe this over the next weeks.
I realized that whenever I would reset the router and satellites to factory default using the physical reset button and then re-setup my home network, the login to portal.office.com would work for not longer than one week because of the Auto-detect setting of the IPv6.
If I disable IPV6 the portal.office.com redirection to my company's secure token service (which is used for the Authentication - just like any other enterprise would use) would again, not work.
I then noticed on the debug.htm page of the router that you have the ability to enable jumbo frames and ICMP response.
As soon as I enabled this and re-enabled IPV6 to Auto, it has started to work.
Could anyone else having a similar setup please do the same thing and confirm to me?
Could also be a good tip if others are having issues accessing AWS services.
- FURRYe38Mar 29, 2020Guru - Experienced User
Jumbo frames should only be enabled if your entire network supports Jumbo frames, i.e. switches and LAN adapters. Otherwise you should disable it.
kdbajaj22 wrote:I think I have finally figured it out but I will have to observe this over the next weeks.
