nanandn
Oct 09, 2020Initiate
Unable to login to orbilogin.com
I am unable to login to orbilogin.com or 192.168.1.1. I get an error " Looks like you’re not connected to your Orbi’s WiFi network. Don’t worry, it happens to the best of us. Try the following steps...
Oct 10, 2020Guru - Experienced User
What modem are you running?
you can get errors like that if you've got a double nat going on. (2 routers on the same network both in router mode)
https://kb.netgear.com/30186/What-is-Double-NAT
- nanandnOct 10, 2020Initiate
I am using xfinity xfi model. Yes. The problem was the double NAT. The modem had changed the IP of ORBI. So I use that IP address, I am able to login. Is there way to change the default IP of orbi to that? I am using orbi in AP mode, so a lot of options are disabled.
- FURRYe38Oct 10, 2020Guru - Experienced User
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktopTry option #2...
