bharatk2020
Apr 26, 2020Follower
Unable to Manually update firmware of RBR50 to 2.5.1.16
Dear Community, I have recently got free ORBI from my service provider but I am unable to update it to latest Firmware which is - RBR50-V2.5.1.16.zip. On NG website its mentioned to upgrade to in...
crazyh
May 29, 2020Tutor
Hi FURRYe38
Tried updating to version RBR50-V2.2.1.210 & 212 but no luck.
Is there any way to unlock the ISP provided Orbi device.
May 30, 2020Guru - Experienced User
Oh it's a ISP version of Orbi.
You can try this:
https://kb.netgear.com/000059633/How-to-upload-firmware-to-a-NETGEAR-router-using-TFTP-client
crazyh wrote:Hi FURRYe38
- crazyhMay 31, 2020Tutor
Tried TFTP (orange color is not glowing as the device is not bricked) also but no luck,
- FURRYe38May 31, 2020Guru - Experienced User
Did you try Windows version of TFTP or NGs downloadable version? I've seen posts were using the other app worked vs the other app. Something to try.
I presume the ISP FW has the RBR locked down and can't be loaded with NG stock FW.
crazyh wrote:Tried TFTP (orange color is not glowing as the device is not bricked) also but no luck,
How to unlock it, is there any coding or trick to do that.
