finny23j
Apr 19, 2019Aspirant
Unable to Map drives after setting up Orbi RBR50 mesh network
I have updated my Netgear router to the Orbi RBR50 Mesh network. Since then I have not been able to map drives to computers around the house. Windows says that it is able to connect but the device is...
- May 02, 2019
Glad you found the problem and fixed it.
Please mark your thread as solved so others will know for future referece.
Enjoy. :smileywink:
finny23j
Apr 22, 2019Aspirant
Firmware: V2.3.1.44
Cisco Type: XB3, Model : DPC39541T
Cleared my mapped drive on the device I setup the share on.
Recreated the share on the device.
Tried to map drive to //IPAddressOfDevice\DataVolume
Verified that firewalls are disabled the windows 10 device
It still failed to map a drive.
Apr 22, 2019Guru - Experienced User
Is this your ISP modem?
If so then this already has a built in router and wifi. This would be a double NAT condition which isn't recommended. Couple of options,
1. Configure the modem for transparent bridge mode. Then use the Orbi router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ or IP Pass-Through for the IP address the Orbi router gets from the modem. Then you can use the Orbi router in Router mode.
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
- finny23jApr 22, 2019Aspirant
I would do one of the options you have suggested, but all my devices are connecting to the orbi network and not at all to the Cable modem network. Are these options still needed?
Thanks,
- FURRYe38Apr 22, 2019Guru - Experienced User
Would be something to try.
Seems odd that you can't map drive for some reason...even with all connected to the Orbi. Ensure all devices are using the same workgroup name as well.
Try this, connect 1 PC and 1 remote share device to the ISP modem. Map drive there work?
- finny23jMay 01, 2019Aspirant
Hey Furry,
Some more investigation with the device I am trying to map to, I found that I had updated the anti-virus to Norton and it automatically blocked filesharing. Once I added the devices as "Trusted Devices" I was able to map drives to them.
Thanks again for your suggestions. It was very helpful.
