finny23j
Apr 19, 2019Aspirant
Unable to Map drives after setting up Orbi RBR50 mesh network
I have updated my Netgear router to the Orbi RBR50 Mesh network. Since then I have not been able to map drives to computers around the house. Windows says that it is able to connect but the device is...
- May 02, 2019
Glad you found the problem and fixed it.
Please mark your thread as solved so others will know for future referece.
Enjoy. :smileywink:
finny23j
May 01, 2019Aspirant
Hey Furry,
Some more investigation with the device I am trying to map to, I found that I had updated the anti-virus to Norton and it automatically blocked filesharing. Once I added the devices as "Trusted Devices" I was able to map drives to them.
Thanks again for your suggestions. It was very helpful.
May 02, 2019Guru - Experienced User
Enjoy. :smileywink:
