Udom
Mar 17, 2018Aspirant
Unable to ping Raspberry Pi connected to RBR50
Tried searching to see if anyone else was having this issue but couldn't find the same situation. I'm trying to setup Octoprint on my Raspberry Pi for 3d printing monitoring. I can connect to my WiFi...
st_shaw
Mar 18, 2018Master
Can you describe more clearly what gear you have and in what order it's wired up? You refer to your "WiFi router" your "main router" and your Orbi. I can't tell what you have going on, but it sounds like you have more than one router, which would cause the type of issue you describe.
If you are using Orbi behind another router, then you need to run Orbi in Access Point mode so all your devices are on the same network.
Udom
Mar 18, 2018Aspirant
Yes, that is correct. I have the main router from my service provider that runs through the house. Home is wires to each room. The Orbi is my wifi router that is connected to this router.
- st_shawMar 18, 2018Master
OK. Then you should run Orbi in Access Point mode. If you do not run Orbi in Access Point mode, then devices connected to your main router will not be able to communicate with anything connected to your Orbi via wire or WiFi, which I believe is what you are seeing.
See page 79 of the manual. http://www.downloads.netgear.com/files/GDC/RBK50/Orbi_UM_EN.pdf
- UdomMar 19, 2018AspirantThanks for the info. Will try this out. Fingers crossed.
