Udom
Mar 17, 2018Aspirant
Unable to ping Raspberry Pi connected to RBR50
Tried searching to see if anyone else was having this issue but couldn't find the same situation. I'm trying to setup Octoprint on my Raspberry Pi for 3d printing monitoring. I can connect to my WiFi...
Udom
Mar 18, 2018Aspirant
Yes, that is correct. I have the main router from my service provider that runs through the house. Home is wires to each room. The Orbi is my wifi router that is connected to this router.
st_shaw
Mar 18, 2018Master
OK. Then you should run Orbi in Access Point mode. If you do not run Orbi in Access Point mode, then devices connected to your main router will not be able to communicate with anything connected to your Orbi via wire or WiFi, which I believe is what you are seeing.
See page 79 of the manual. http://www.downloads.netgear.com/files/GDC/RBK50/Orbi_UM_EN.pdf
- UdomMar 19, 2018AspirantThanks for the info. Will try this out. Fingers crossed.
