hankT
Jan 31, 2019Tutor
unable to register product - already registered AC3000
I am trying to register my router I purchased refurbished from Amazon today and am being told the router was already registered and need to enter another number. I saw other solutions where the Netg...
hankT
Jan 31, 2019Tutor
Not seeing any reply/solution
Jan 31, 2019Guru - Experienced User
Did you check your Private messages? michaelkenward sent you a private message...
- hankTJan 31, 2019TutorYes. I checked both my personal email and messages with private mailbox in Netgear community. Is there somewhere else to check?
- michaelkenwardJan 31, 2019Guru - Experienced User
I was suggesting that you should send a private message to the Netgear people.
Blanca_O or ChristineT or DarrenM
Thanks All. I have been sent the requested information through private message to Blanca. this should resolve my issue. It appears if you purchase a refurbished product which has previously been registered, it has to be manually overridden. Otherwise, you cannot register.
