Ramesh09
Feb 13, 2019Aspirant
Unable to rename my satellites
Bought the whole package with ORBI router-Modem and 2 satellites. everything configured and now trying to test out my mesh nw but both sats has the same name RBS20. Tried to rename these so I can dis...
ekhalil
Feb 13, 2019Master
When you click on "Attached Devices" in the web GUI you will see this regarding the satellites:
You can see two names: Device Model and Device Name. You can change both of these if you click on names and edit them as follows:
Ramesh09
Hi, That is exactly what I am doing. When I change the name and apply changes, I see it accepts the name and after about 10-20 secs it resets the itself to RBS20 as the name.
- ekhalilFeb 13, 2019Master
- You need to do the name change while the satellite is connected.
- Can you please take a snapshot of the satellites' status in Attached Devices like the ones I posted.
- To which names have you tried to change to?
