L58
Sep 21, 2020Aspirant
Unable to send out gmails
I have set up my RBR50 mesh wifi with 1 satellite. When using the Orbi wifi network all my gmail outgoing messages from my iphone (model XS) do not go through. If I change to another Wifi network eve...
Sep 21, 2020Guru - Experienced User
Is Armor, Circle, or IPv6 enabled on the RBR?
- L58Sep 21, 2020Aspirant
The firmware for the router and the satellite are : V2.5.1.16
The internet provider is Post Luxemboug ( the state telephone Co)
The Modem model is the Fritz Box 7490 - this is the standard modem that come with the installation of the internet
Armor, Circle or IPv6 is not enable on the RBR
Thanks for any help
Luigi
- FURRYe38Sep 21, 2020Guru - Experienced User
Need to check your ISP modem as this modem has a built in router already. Is this modem bridged or working router mode?
This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktopCheck with your ISP if they can help you bridge the modem if possible.
Thanks
I will try tomorrow ( now is 00.36 am in Luxembourg) to contact the ISP
I hope they can help me.
Will keep you update of the developments
Best
Luigi
