toddinpal
Jul 18, 2020Aspirant
Unable to setup RBR50 and a satellite
Last year I moved to a new house that had essentially no Ethernet wiring, so I decided to purchase the RBK53 as it was a 3 story structure, a router or satellite on each floor. I got that set up, al...
toddinpal
OK, well I have already used TFTP to update both the router and the satellite to V2.5.1.32.
I've tried various resets of both the router and the satellite and nothing has seemed to work so far.
I tried again setting up the RBR without being connected to the modem. I then connected to the modem and after a few shenanigans I was able to get it and the Internet. However I am still unable to add the satellite. When I press the sync buttons on both, and they are 3 feet away from each other, they both go to flashing white top LEDs. The satellite goes to solid blue, then goes to solid magenta, while the router remains blinking white. After that nothing changes that I can tell. :-(
Any help to get these set up together would be greatly appreciated!
-tl
Jul 18, 2020Guru - Experienced User
Try 10-15 feet away. 3 feet maybe too close.
Can you access the RBS web page if you reset the RBS and connect a Wired PC to the back?
Might try a factory reset on the RBS then connect the RBS with a ethernet cable to the RBR and see if it might sync.
If that fails, possible the RBS could be faulty if it won't connect at all.
- toddinpalJul 19, 2020Aspirant
Well I think it might be the router and not the satellite. I reset the router and now it appears to be in a boot loop. It goes from white abrupt flashing light, to white smooth flashing light, Then it goes to solid white light, followed by a green flash, orange flash, orange flash, and then white abrupt flashing. This repeats indefinitely. Meanwhile my computer connected via a cable to the router is trying to ping 192.168.1.1 and it goes from:
PING: transmit failed. General failure.
to:
Reply from 192.168.1.1: bytes=32 time<1ms TTL=64
to:
Request timed out.
to:
Reply from 192.168.1.2: Destination host unreachable.
and basically repeats.
- FURRYe38Jul 19, 2020Guru - Experienced User
Sounds like the RBR is bad unfortuneately. :smileyfrustrated:
- toddinpalAug 13, 2020Aspirant
At times the router shows the satellite connected, but connected as a device and not a satellite as the attached picture shows. What would cause this?
-tl
- MstrbigAug 13, 2020Master
toddinpal wrote:Well I think it might be the router and not the satellite. I reset the router and now it appears to be in a boot loop. It goes from white abrupt flashing light, to white smooth flashing light, Then it goes to solid white light, followed by a green flash, orange flash, orange flash, and then white abrupt flashing. This repeats indefinitely. Meanwhile my computer connected via a cable to the router is trying to ping 192.168.1.1 and it goes from:
to:
to:
Request timed out.
to:
Can you tell what methods you used to reset the router?
I have had some experiences with stubborn routers not really resetting. The last one, no matter how long I pressed the reset button, it would not reset. Remembering TVs, other routers, smart switches, etc. sometimes have to be discharged, I shut off and unplugged the router, held the reset and power button in for 1 minute, let go of buttons, pressed and held the reset buttom then turned on the router. Finally the power light did what it was supposed to do and flashed red. I unplugged the router, plugged it back in and powered it up and it worked. I'm not saying this will work for you, but it did for me.
