manderson240
Jul 08, 2023Aspirant
Unable to sync/add new ORBI RBS50v2 to existing network of RBR50 and one RBS50
Current OS is Windows 10 with a simple network consisting of a RBR50 and one RBS50 purchased new and installed for our church in 2020. ORBI system has performed great since installation. Firmware (FW...
- Jul 12, 2023
SUCCESS!!
As noted in my prior post on 2023-07-12 11:37 AM, the last step to resolving the issue was to add the new RBS50v2 satellite to existing network (via sync button on satellite and then sync button on the router) and update firmware. The RBS50v2 synced/added successfully. Firmware on new satellite was shipped new with 2.5.2.4 so it was updated to 2.7.3.22 to match the RBR50 and RBS50 that was already on our network (firmware had been updated from 1.1.0.16 to 2.7.3.22 on existing devices as noted in prior post). Logged in to router and verified all devices were on 2.7.3.22 and checked network to be sure wifi was working in all areas of church campus --- everything working as expected.SpeedTest (OOKLA) was about the same in all areas.
Thanks to CrimpOn and FURRYe38 for their input in resolving the issue.
The info from FURRYe38 about disconnecting the RBR from the ISP modem to avoid any auto updates would probably have saved me a lot of time.
manderson240
Jul 10, 2023Aspirant
Thanks for the info.
I was able to determine the FW version is 2.5.2.4 in the new RBS50v2. I connected it to the router via ethernet and used orbilogin on desktop PC.. The new sat appeared to connect based on the blue light that came on after it was connected to router via ethernet cable (I did not push sync button on either device). I doubt it would work properly with the different FW versions.
I plan to update old sat then the router to 2.2.1.212, then update old sat and router to 2.5.2.4 to get all three devices to 2.5.2.4. Then I will sync/add the new sat to the network. Will post results, but it may be a couple of days.
Assuming this works I will plan to update both sats and the router to curent FW after all are showing via orbilogin.
manderson240
Jul 12, 2023Aspirant
UPDATE: not there yet, but making progress. Experienced couple of automatic updates (??) during the process that kept Sat and Router out of sync on FW version. Information below provided so others may benefit from my experience doing the updates - first time I have tried updating ORBI firmware.
Below is a summary of activities completed to get our network to current status (Sat and Router both on 2.7.3.22):
I was unable to update from v1.1.0.16 directly to v2.2.1.212 -- get 'File is incorrect...' msg, so I went back to version that file would work with the update process.
1. Updated (Upd) Sat & Router to 1.4.0.18 - ok
2. Upd Sat & Router to 1.8.0.6 - ok
3. Upd Sat to 2.0.0.74 received msg at end stating 'This site cannot be reached...(IP address took too long to respond) - timed out' that stayed on screen for couple of minutes then received normal completion message and the correct version was displayed on screen. Assumed (probably not safe assumption) it was okay.
4. Upd Router to 2.0.0.74 - ok
5. Upd Sat to 2.2.1.212 - received site cannot be reached msg again and finally got the completion screen (green circle with check mark). But the version was actually updated to 2.7.3.22 based on display. Router still on 2.0.0.74 - network is working.
Did not try to update router to 2.2.1.212 - so i tried to get Router to 2.7.3.22
6. Upd Router to 2.7.3.22 - failed - did not record the message received?? - So now Router is still 2.0.0.74 and Sat 2.7.3.22
Since new RBR50V2 Sat to add is at 2.5.2.4 decided to try and get Sat & Router to 2.5.2.4.
7. Upd Sat to 2.5.2.4 - ok after two attempts - and connecting ethernet cable to Sat via Router. Received msg about going to previous version and continued-- seems to be okay. Now to get Router to 2.5.2.4 (should be a breeze, right?)
Router is still 2.0.0.74 and Sat 2.5.2.4
8. Upd Router to 2.5.2.4 - receive File is incorrect message
9. Upd Router to 2.2.1.212 - receive File is incorrect message
10. Upd Router to 2.2.1.210 - ok
11. Upd Router to 2.2.1.212 - seemed to work ok, but after completion it appears it actually updated to 2.7.3.22.
12.Upd Sat to 2.7.3.22 - ok
I see the new screens when logged in to Router via web browser (both show 2.7.3.22 as version).Get a message that Armor is not installed. One screen shows a message that Firmware is downloading and this eventually changes to a link with 2.7.4.24 (assume this can be clicked to install online?). Somewhere along the way I had to change Admin password because of new security requirements?.Network seems to be working okay at 2.7.3.22 after updates.
NEXT STEPS:
Add the new RBR50v2 Sat (which was the goal from day one) to the network and update to 2.7.3.22 (from 2.5.2.4). When this is completed I plan to let 2.7.3.22 run for a while and then update Router and both Sats to current FW (2.7.4.24?)
WILL PROVIDE UPDATE WHEN AVAILABLE (hopefully it will be short)
- FURRYe38Jul 12, 2023Guru - Experienced User
Might do this with the RBR disconnected from the ISP modem to avoid any auto updates from happening. Just have all the FW files you need downloaded.
- manderson240Jul 12, 2023Aspirant
Thanks for the suggestion FURRYe38. I will definitely file this information for future reference.
Certainly did not know that was an option.
This was a good exercise for my old brain cells (but also created some frustration) while working on this for our church. I am an old retired IT software development/support guy (mainframe background) that does not know how to give up on this type of challenge.
Thanks again!
SUCCESS!!
