Pwmzm's avatar
Pwmzm
Follower
Feb 15, 2019
Uncategorized, RBR20
Netgear Orbi Router RBR20
Firmware Version: v2.2.1.210 (firmware is up to date)
Windows OS on devices
residential environment
On a regular basis the History on the Circle app shows "uncategorized" with 4 sets of numbers with a period between each set (assuming IP addresses). When I touch one of these the only option is "Visit Website", which never works. There appears to be no way to block these from being accessed, even though I don't know what they are. They will show up on a device someone is using, or even at times when I know a device is not on. I do not feel it is good to assume that it is no problem but cannot figure this out. Can anyone help? TIA
  • FURRYe38's avatar
    Have you set up IP address reservations ON the Orbi router for your devices that you manage with Circle?
