Orbi_in_NC
Nov 28, 2019Aspirant
Unidentified device removal
Hello all! I have an unidentified device on my network. I curently have it "Blocked" but would like to actiially remove the device but I cannot find any method to do this. I've look in the user guie...
- Nov 28, 2019
Orbi_in_NC wrote:I've look in the user guide and on various threads but cannot find a method to remove, delete, erase this device
This is correct. It is not clear (to me) why Netgear chose to interpret "Block" as meaning, "Give this device an IP address, but do not let it communicate."f When it is no longer connected, it will disappear.
This must be a device connected over WiFi (otherwise you surely would have found it by now). One way that is sure to work is to change the WiFi password. Which is too ghastly to imagine doing! (With all my Internet of Things devices that have no keyboard or camera, it would mean physically resetting and reconfiguring all of them. OMG. No Way!)
Perhaps a more practical compromise would be to determine what kind of device it might be by looking up the MAC address in one of the many web databases to see which vendor might have built it: https://www.macvendorlookup.com/
For example, if the MAC says "Apple", then it's probably an Apple product. How many of these can there be in one house?
CrimpOn
Nov 28, 2019Guru - Experienced User
- Orbi_in_NCNov 28, 2019AspirantThanks! I did the mac lookup and it’s an apple device of some sort. The hunt is on!! Password reset is a good option as i dint have that many devices to manage; more than I thought though. Thanks for the help!
- CrimpOnNov 28, 2019Guru - Experienced User
I always forget about the iPod Plus that is connected to our stereo (yes, "stereo"). Good Hunting!
Haha, thanks! Sneaky lil devices!
- FURRYe38Nov 28, 2019Guru - Experienced User
Let us know what you find out.
