nameuser
Sep 13, 2020Tutor
UniFi Dream Machine as main router with RBR50 and RBS50 as APs ?
Is it possible to use a UniFi Dream Machine (UDM) as the main router with the RBR50 physically connected to the UDM in AP mode and have my RBS50s still work as wireless satellites?
- Sep 14, 2020
nameuser wrote:Mstrbig Thank you. I'm primarily considering the UDM for its traffic management and Security Gateway (IPS and DPI) features. Any idea if the UDM would be able to recognize traffic reaching it through the Orbi AP and satellites? since most devices will end up connecting to the Orbi router and satellites if the UDM WiFi is turned off.
If your Orbi is connected to the UDM and the UDM router is handling all DHCP, and the Orbi is in AP mode, all traffic will be handled by the UDM, regardless if WIFI is disabled on the UDM. All traffic will still be routed through the UDM.
Mstrbig
Sep 13, 2020Master
nameuser wrote:Is it possible to use a UniFi Dream Machine (UDM) as the main router with the RBR50 physically connected to the UDM in AP mode and have my RBS50s still work as wireless satellites?
Yes, however, I would disable WiFi on the Dream Machine, to avoid conflicts.
They could co-exist if your WIFI channels are different and you don't have a lot of neighbor traffic.
You would just have 2 separate WIFI networks.
My setup use to be that way and I never had conflicts. But I made sure my WIFI router was on one WIFI channel and my Orbi WIFI was on another channel for both 2.4 and 5Ghz.
nameuser
Sep 14, 2020Tutor
- MstrbigSep 14, 2020Master
