DavidBQ
Aug 23, 2019Aspirant
Unique SSIDs and Password
I require separted SSIDs for some of my older Smart Home Devices. I was wondering if via Telnet there is a way to not only rename each SSID uniquely but set the password for each SSID uniquely? I...
- Aug 25, 2019
I am unsure what compelled you to post such a very uncool comment to my thread and quite frankly don’t care to understand why. You have offended me; therefore, I would respectfully ask going forward you reframe from commenting on any of my threads.
Unfortunately this forum does not provide the standard tools to delete comments or block users.
Given that you have hijacked this thread with such a manner of response and I don’t want it to spiral any further I am closing it.
Retired_Member
Aug 23, 2019
FURRYe38 wrote:Separation of SSID is not supported on Orbi.
I'm pretty sure the OP is NOT asking if SSID separation is supported by NG bu t rather can it be done.
There are tons of posts here from successful users using TELNET.
DavidBQ
Yes as I stated I realize separating SSID can be done (I have review the posts). What I am asking is can you then asign a different password to each SSID once separated via Telnet. If so how?
- Retired_MemberAug 23, 2019
DavidBQ wrote:Yes as I stated I realize separating SSID can be done (I have review the posts). What I am asking is can you then asign a different password to each SSID once separated via Telnet. If so how?
I can't tell you the details, but what I read it sounded like other were successful. The process is not for the faint at heart. Not sure about the password option ..??? Have you considered the guest network?
I ran into this somewhat problem due to a device that was to be setup using the Iphone which had to be on 2.4 Ended up turning down the 5g signal at the router and unplugging the Sats. Once complete turned everything back to normal.
I suppose you have your reasons for wanting to do this.
