DavidBQ
Aug 23, 2019Aspirant
Unique SSIDs and Password
I require separted SSIDs for some of my older Smart Home Devices. I was wondering if via Telnet there is a way to not only rename each SSID uniquely but set the password for each SSID uniquely? I...
- Aug 25, 2019
I am unsure what compelled you to post such a very uncool comment to my thread and quite frankly don’t care to understand why. You have offended me; therefore, I would respectfully ask going forward you reframe from commenting on any of my threads.
Unfortunately this forum does not provide the standard tools to delete comments or block users.
Given that you have hijacked this thread with such a manner of response and I don’t want it to spiral any further I am closing it.
michaelkenward
Aug 24, 2019Guru - Experienced User
Another curiosity question, have you tried changing the SSID on the Orbi to something that the devices recognise?
Better yet, why are you asking for this?
Why do you require "separated SSIDs for some of my older Smart Home Devices"?
Tell us what you really need to do without jumping to conclusions about how you should go about it.
In other words, start by explaining what you are trying to connect. You may be jumping to the wrong conclusion when you ask about changing SSIDs.
DavidBQ
Aug 24, 2019Aspirant
Wow kind of disappointed I can't get a simple answer. All I was looking for is a "yes, this is the command" or "no, that functionality is not available". Thanks for offering your help in analyzing this but its not required in this instance, research done, conclusion determined. So can some please just provide a direct answer to the question "via Telnet there is a way to not only rename each SSID uniquely but set the password for each SSID uniquely"? Thanks in advance for only answering the question.
