DavidBQ
Aug 23, 2019Aspirant
Unique SSIDs and Password
I require separted SSIDs for some of my older Smart Home Devices. I was wondering if via Telnet there is a way to not only rename each SSID uniquely but set the password for each SSID uniquely? I...
- Aug 25, 2019
I am unsure what compelled you to post such a very uncool comment to my thread and quite frankly don’t care to understand why. You have offended me; therefore, I would respectfully ask going forward you reframe from commenting on any of my threads.
Unfortunately this forum does not provide the standard tools to delete comments or block users.
Given that you have hijacked this thread with such a manner of response and I don’t want it to spiral any further I am closing it.
michaelkenward
Aug 24, 2019Guru - Experienced User
You are asking for information that is outside the remit of "official" support channels. Advice on playing around with Telnet is not something that you will get from the Netgear team.
Yes, there are non-Netgear people here, but they too usually stick to familiar territory, just as they do when people ask about third-party firmware. That's best handled over in places where they create it.
If you aren't prepared to go into the underlying issue – such as the devices involved – then you would do better to seek help outside the Netgear community.
That you are not prepared to divulge basic information makes it hard to say more. Telling us that "This is not the first community I have been on with this issue" tells us not ,much it simply raises the question, why did you faff around elsewhere when you are trying to fix a Netgear device? Nor does it tell us anything about the possibly dodgy advice that you received elsewhere.
Many of these "how so I connect my stuff?" issues get solved when people don't mind saying what it is they want to connect and what foes wrong when they try to connect it.
No one is trying to be awkward, simply to get to the bottom of the problem. Good luck with whatever search engine you favour.
DavidBQ
Aug 25, 2019Aspirant
- michaelkenwardAug 25, 2019Guru - Experienced User
DavidBQ wrote:
Given that you have hijacked this thread with such a manner of response and I don’t want it to spiral any further I am closing it.I'm afraid you have done nothing of the sort.
By marking this as SOLVED you have opened the door for people to think that it arrived at some sort of resolution of your problem.
This is far from the case, mostly because you have not provided enough information to understand what that problem might be.
You also have a funny interpretation of what denotes a "hijack".
