Jjgalaska
Jun 24, 2018Tutor
Unknown Connection
Im having an issue with things not staying connected. In the device liat it shows devices connected to the 2.4 band. The 5 band. And... wth is the unknown connection type. It is NOT unknown device. It...
Jun 25, 2018Guru - Experienced User
Depending upon where they are connected, they should show on the router anyways since it reports whats all connected.
Also log into the satellites web page and you should see them connected there as well.
Try changing channels...
Jjgalaska
Jun 27, 2018Tutor
Well. I did I bunch of things so I am not sure what it was that worked. But, when I went into the router settings, I turned on beam forming, changed the 2.4 channel, and the seitches have been on without disconnecting. However. Some the switches are in my attic above the garage, and switches on the far side of garage all are connected. I have my outdoor Orbi satellite on the wall in the garage. According to to ap, nothing is connected to it at all. I figure one of two things is happening, it doesn’t work because it’s closest to the switches and they are not connecting to it. Or, they are connected to it but the ap sucks and isn’t accurate. It seems like the outdoor orbi has some different issues than regular satellites. It has its own button in the ap also, so its probably not displaying correctly.
Anyway. Thank you very much for helping me troubleshoot this. All my Sonoff switches are now working!!
- FURRYe38Jun 27, 2018Guru - Experienced User
Glad to be of help. ENjoy.
