cupoftea
Nov 01, 2020Aspirant
Unknown device connected with unknown connection type? Nefarious or harmless?
Intermittently I seen an unknown device show up in my attached devices list on the Orbi app, always with the DEV prefix and with device type "network". It usually shows as connected to my upstairs sa...
CrimpOn
Nov 01, 2020Guru - Experienced User
I seem to recall that "inline" images have to be approved by a forum moderator, while "attachments" do not.
That may be why the inline images are not showing up -- yet.
Do you by any chance have an iPhone or iPad that recently got a firmware update?
cupoftea
Oh I see! Attached the first screenshot here. No firmware updates recently - I installed the Orbi after we'd all got iOS 14, and have turned 'private address' off on all iOS devices in the home.
- cupofteaNov 01, 2020Aspirant
I meant to add; I've tried looking up the MAC address but no manufacturer comes up. Attached the second screenshot here. I'm on firmware V2.5.2.4.
- CrimpOnNov 01, 2020Guru - Experienced User
cupoftea wrote:I meant to add; I've tried looking up the MAC address but no manufacturer comes up. Attached the second screenshot here. I'm on firmware V2.5.2.4.
The "app" is probably reporting the device name as "DEV" plus the last part of the MAC address and the type as "Network" because the MAC does not match any vendor in the table (as we both have discovered). "no match".
It might be worth a few minutes to open the Settings...WiFi" on those "i-Things" and see what the last part of the MAC address is on each of them. I am not 100% certain, but I have a feeling that iPhones substitute for the vendor code and do not change the last part of the MAC address.
This may have nothing to do with the problem (What I know about the "app" is really primitive. We "DOS Lovers" tend to stick with the web interface and secretely wish Netgear had provided a command line interface!)
- cupofteaNov 09, 2020Aspirant
Many thanks for the response. I have checked the i-Things and none of them match. The rogue device hasn't returned yet but will keep an eye out for it.
By the way, the Orbi does allow shell access via telnet. You can enable this on the debug page.
