Patrick-Gowers
Mar 14, 2022Aspirant
unknown host ngxcld.com causing Netgear Orbi kept showing magenta indicator
To Netgear support engineers, Can you please help to check the DNS settings of ngxcld.com. My understanding is that Orbi timely accesses this ngxcld.com to check its Internet connectivity. ...
Patrick-Gowers
Ah,,, my bad taking this to the wrong place...
where would be a good place to report such issue? maybe I should mail Netgear tech support?
BTW, do you observe same issue on your side? Can you help to test the ping connection to ngxcld.com?
microchip8
Mar 14, 2022Master
You can contact support and ask if the hostname/server is down. I'm not able to ping it either so it's something on their side
