Noroddveien's avatar
Noroddveien
Apprentice
Jan 21, 2019
Unknown Wi-Fi network NETGEAR60
Hi,   I have a RBR50 and RBS50 satellite.  I have named my Wi-Fi network Orbi3000 but in addition a network called NETGEAR60 always shows up.  I assume it is my satellite (back hauled to RBR50) b...
  • ekhalil's avatar
    Jan 21, 2019
    This must be the backhaul network.
    The backhaul network is broadcasted by the router (you should see the MAC address of the router) on the 5 GHz band (unsualy channel 108 and uppwards). If you have Daisy Chain enabled then you will also see the same network broadcased for every satellite as well, so if you have 1 satellite then you will see 2 such networks with hidden SSID from 2 different MAC addresses, one for the router and another for the satellite.
    This channel has no SSID so it seems that the name NETGEAR60 is only given to the network by your Wifi analyser since it knows the vendor of each network by it's MAC.This name is not broadcasted by Orbi for sure.
