Fredarmijo
Mar 25, 2020Aspirant
Unmanaged switch support for multiple routers
I am trying to connect an orbi router and an Apple Airport Extreme router to my switch, in which the modem is also connected. The orbi works fine, but the Apple AE does not. What might I be doing w...
Mar 25, 2020Guru - Experienced User
Standard configuration of switches are always behind the router, never in between a modem and router.
You'll need to get with apple support in regards to configuration of the Apple AE device with your modem.
If you need help with your NG switch, please post in the switch forum:
https://community.netgear.com/t5/Unmanaged-Switches/bd-p/business-unmanaged-switches
