steelhorse83
Apr 23, 2018Guide
Unreliable Ethernet Backhaul
Here's a little background on my setup: RBK53 (Router & (1) Satellite in the house, (1) Satellite in a detached garage) All three units are running 2.1.3.4 (factory reset the satellites after up...
- Apr 23, 2018
Please do a factory reset and set up from scratch with the router. v2.1.3.4 has some major changes in it and needs a factory reset and set up from scratch for this version. Other users have said there problem continued after updating FW with out resetting there router. Problems went away after resetting the router and setup from scratch. Try this first please.
I saw an similar issue with mine as well. Reset cleared it.
Apr 23, 2018Guru - Experienced User
steelhorse83
Apr 24, 2018Guide
I did a factory reset on the Router last night, and so far everything is working as expected. I was also seeing inaccurate "Connection Type" and "Connected Orbi" entries in the Attached Devices list, which seems to look right after the reset. I'll update this thread if the anomolies return.
Thanks!
