lacostej
Oct 14, 2021Aspirant
Unreliable router & Access Control features
Hello I've had a RBK23 system for about a year. I am using the Access Control system to control access for my kid devices. I have been running into issues regularly since the begining. 1....
CrimpOn
Oct 19, 2021Guru - Experienced User
1. using the UI to block / unblock the devices is unreliable. One needs to wait 10/30s before refreshing the UI otherwise the data returned to the UI is out of date.
2. it is impossible to allow a non connected device from the Android app. Because of this I wrote a command line tool to block/allow set of devices based on their mac addresses. It's practical because it's much faster and reliable than the UI. (*)
3. but allowed devices get blocked regularly. Without doing anything. Rebooting doesn't help. I sometimes switch WIFI off/on and it fixes itself. Sometimes I reboot the router and it works again.
The last element is really really annoying. This week I've had to turn off the AccessControl system a few times. It just doesn't work or randomly breaks.
E.g. when it blocks my own computer:
command line tool: (I am assuming you have found a way to enable telnet on the router, which was removed from the debug screen by firmware V2.7.3.22.) Bypassing the router firmware on the command line to directly manipulate router network tables may have unintended consequences.
It is no surprise to hear that the Orbi app does not seem to function correctly. The forum is full of comments about how the app fails to deal with devices correctly (and the network diagram).
I have a suspicion that the solution to the underlying problem may lie on the kids actual devices, not on the WiFi router. I know parents who use Family Time to regulate the amount of screen time their children have.
I sincerely wish there were an easy, obvious, (and free) solution to regulating kids use of technology. From what I see on the various forums (here, the app forum, the Parental Controls forums), no one seems particuarly satisfied.
