Vandergraff
Jan 06, 2019Apprentice
Unsecured (disabled) Guest Network
Similar to this closed topic https://community.netgear.com/t5/Orbi/New-Unsecured-networks-on-Orbi-RBK50/td-p/1481297
Today I did a scan using Acrylic WiFi scanner (https://www.acrylicwifi.com/e...
ekhalil
Jan 06, 2019Master
When disabling (or enabling) the guest network by toggling the tick in the ssettings you nned to do "Apply" and the system will reboot to apply the settings, otherwise the setting will still be there and will only take effect after a reboot.
Can it be that when you first unticked the guest network you did not click on "Apply"?
- VandergraffJan 13, 2019Apprentice
Thanks - but I did apply the changes
