JPPMD
Jul 06, 2018Guide
Unstable network—need advice (warning—long)
I would appreciate some help and advice from this community (and the experts like furry and any Netgear folks) on how to get my network faster and more stable. Here are the details:
Comcast Gig...
Cmo1
Jul 07, 2018Apprentice
This is a tough one to really get to do what you want it to do. I have a similar setup in my home.
1. I found more stability if I used the Orbi in access point mode and allowed my router to handle the assignments and routing on my Comcast Gigabit connection. I leave wireless off on the router but enable only dhcp and NAT and then put the orbi into access point mode. I find my speeds faster and my connection stability better.
2. The wired backhaul is extremely buggy right now. I've had to reboot and unplug the hard wires from the main router anytime it loses the internet connection. Otherwise it completely freezes and does nothing. If you look at the logs, for some reason the Orbi main router sees the satellites hard wired connection after a reboot as a denial of service attack and basically becomes unusable. So the only solution for that is to unplug the hard wires from main orbi, allow the wireless backhaul to sync, and then plug hard wires back and allow 5 minutes for wired backhaul to sync. This doesn't always work on the first try either in my experience. I've had to reboot up to 5x and repeat this to get it to work. This is one of the main issues that really irks my soul and I cannot understand why Netgear has been absolutely and totally unresponsive in all firmware updates about fixing it. To answer your question regarding speed, yes the wired backhaul will produce faster connection at the satellite. I get the same connection speeds at all satellites with wired backhaul operating. Usually I get in the neighborhood of 500-600 down and 45 up. If you have a power outage with the wired backhaul right now, my guess is Orbi will freeze just like it does now unless you do the manual unplug/wait /replug routine. I see above you did get wired backhaul to work with time, so maybe that's your answer.
3. Try turning off fast roaming. This may be different for you with the size of your house, because mine is only about 2000 sq ft and the issue I have is that with it on, some units will default to the 2.4 ghz band instead of 5 ghz. Obviously 5 ghz is faster and so you want that in most instances. If this seems to make things worse or doesn't really change anything when you test it, I see no harm in leaving on.
4. Try reducing the wireless power for the 2.4 ghz band down to 25% and set the preamble on both bands to short preamble. Short preamble will send less info over the network and as such should make response time a bit better. The reduction in the 2.4 ghz power level is due to the fact that the Orbi does not manage connecting to the 2.4 and 5 ghz bands well. There should either be an option to default to the 5ghz band when available or the algorithim in the firmware should automatically do that, however it does not. As a result you will often have devices connecting to 2.4 ghz when the 5 may be available due to the fact that the 2.4 ghz signal will be slightly stronger and connect further. When I place 2.4 ghz at 100% power the speed and performance has always suffered. In your case with a larger home, you may need it at 50%, but start at 25 and test.
5. Believe it or not, 4th Gen and prior apple tvs do NOT have a gigabit LAN port onboard. As a result, it's better to let them connect wirelessly as they will actually connect faster. If you have 4k apple tvs, they DO have a gigabit port so you can hardwire without performance suffering.
6. Don't allow Orbi to auto select channels. It switches constantly and causes unstable connection. I use channel 48 for 5 ghz and channel 11 for 2.4 ghz. I know you said your neighbors are using 1,6 and 11, so you may want to play with that a bit and try different channels. Same with the 5 ghz if they use channel 48. But again, don't leave in auto. That is no doubt some of the instability, dropping and reconnecting constantly.
7. I don't enable the guest network, it seems to cause stability issues.
8. I'm unsure if the daisy chain topology helps things in either wired or wireless setups, because my router is in the middle and my satellites are at both ends, so I haven't ever tested the daisy chain. I turn it off for me. Maybe someone else here will chime in about whether that feature actually works or not.
9. I haven't heard you mention the QoS feature, but I can tell you it is broken. Don't go to the tab and don't run a speedtest from it, it will mess up network speeds royally. Another feature Netgear promised will work, but never has.
10. I know you mentioned some port forwarding rules and address reservations. I have a few and again I let the router/gateway handle as well since Orbi disables those in ap mode.
Your post may have been long but I feel like my response was so much longer...lol. Sorry for all the reading, but I hope maybe some of this will help you. What it boils down to is that Netgear really hasn't released a firmware yet that completely addresses all these issues. The hardware is best on trhe market, but without good firmware to drive it, you have tio tweak constantly. Hopefully, they will hear our complaints and fix this stuff soon but I'm not holding my breath.
Comcast Gigabit Internet through their proprietary gateway. Tests at like 800-900 when hard wired.
Gateway is set up in Bridge mode and Wi-Fi OFF.
Connected with a known good Cat6 patch cable to my Orbi RBR50, set up with DHCP/NAT, the usual 192.168.1.2-256 addressing, with 3 address reservations and port forwarding for key devices.
The RBR50 is connected by a known good Cat6 patch cable to an UNmonitored Netgear ProSafe 16 Port Gigabit switch.
These 3 devices are in a downstairs room in my multi-level house (and connected to an UPS).
The switch connects to lots of Cat6 cable running around my new construction 5000+ sq. ft. multi-level house. I have a number of ‘hard wired’ devices (Apple TVs, Alarm system, DVR, Synology NAS, Lutron Caseta, SolarCity monitor, Denon AV receiver), as well as many Wi-Fi devices (3 iPhones, 2 iPads, 2 Amazon Echos, 2 cars, etc).
To extend my Orbi network, I have 2 RBS 50 satellites. One is 2 floors up and slightly off axis from the router (about 30-40 feet), and communicating through radiant heated floors (so floors have water lines and 2” concrete slabs, but no rebar). This is currently connected by 5G wireless backhaul (Good connection). The 2ndRBS50 is in an office only 1 floor up from the router, but off axis and maybe 30-40 feet from the router. This is currently connected by 5G wireless backhaul (Good connection), but interestingly is daisy chained to the upstairs unit (not in a ‘star’ topology when I check the app).
All Orbis are on firmware 2.1.4.16. All have been rebooted since firmware update.
On the RBR50, I do have Enable Daisy Chain Topology ON (but thought that this only worked for 3 or more satellites). I also have Beam Forming, MU-MIMO, and Fast Roaming ON. My RBR50 is grabbing channels automatically, and is utilizing Channel 4 (my neighbors have devices on 1, 6 and 11, so maybe the Orbi knows what it is doing).
When standing next to the router, on my Mac I get like 500-600 Megs download speed (great). At the office satellite, I get like 250-300. This is even if I switch Wi-Fi off and on, to be sure the Mac grabs a new connection to the satellite.
So here are my questions/issues:
If I unplug a satellite to move it, or have a power outage, the whole Orbi system does not seem to gracefully self-reboot and recover. The satellites don’t seem to easily find the router. Lots of blinking lights on top, some purple and orange lights, and after many crossed fingers, I get the blue light and a backhaul connection. Once the network seems to be connected, the Wi-Fi is constantly connecting and disconnecting (drops out frequently). It takes like a half a day before everything stabilizes. Is this a ‘feature’? Why so unstable and hard to reboot/reconnect?
I would like to use wired backhaul for my Orbi system, as I assume that it would improve my Wi-Fi speeds when devices connect to a satellite. But when I try to attach a good Cat6 patch cord from the satellite to my home network (connected through the Netgear switch to the router), there seems to be a whole lot of trouble getting the router to connect over Ethernet, and in the meantime my satellites go brain dead (is the router trying to re-negotiate a connection to the satellite?). Is there a magic sequence to connect and reboot devices (router, satellites) to get wired backhaul working? From what I read here on the community forums, wired backhaul is kind of sketchy. And if I do get a wired backhaul working, will it gracefully recover after a power outage?
When Comcast Internet goes down (regrettably more frequently that I would like), it seems like when it comes back, the router does not always find the Internet/IP? Is the RBR50 smart enough to try to grab a new lease?
Sorry for the long post, and all of the questions. I really need a robust bulletproof system. I have migrated from Apple Airport since it is legacy and EOL, and thought that the Orbi would be a more modern upgradeable and stable system.
Thanks in advance for any advice and assistance.
RocketSquirrel
Jul 07, 2018Luminary
tl;dr
I concur that Orbis kill your network after a power failure. My Motorola modem & Asus router & main Orbi AP are all on a UPS. My 2 Orbi satellites were not. A 2-second power outage required rebooting EVERYTHING, including the devices on the UPS!
I bought 2 more UPSes for the sats. My network never goes down now. I had a 10-minute outage the other day, and my network survived without a hiccup.
You can get an APC Back-UPS for US$40 or so. Well worth it.
- JPPMDJul 07, 2018Guide
RS:
Indeed I have all of my networking stuff on UPS (gateway, modem, Orbis, switches, 1 Apple TV, Lutron Caseta hub) as well as my computers, Synology NAS, and inkjet printer. I just need to get to a solid stable configuration.
See my cross post to Chris--I managed to crash back tonight and am back on a wireless backhaul.
Thanks for the info.
- RocketSquirrelJul 07, 2018Luminary
Oddly, once I got wired backhaul finally to work, it has always worked ever after. I’m on the latest fw, but even the previous fw worked for me. Hence my conclusion that Orbi success is random.
