tarzan_nojane
Aug 03, 2020Star
Unsuccessful recovery or firmware downgrade (RBR20)
Power ON: RBR20 LED ring never stops flashing white (power LED green) I seem to be able to get to recovery mode by holding reset button for 20+ seconds during power on until I see a ping response...
Aug 03, 2020Guru - Experienced User
I would make contact with NG support about this and see what your options are.
tarzan_nojane
Aug 03, 2020Star
Warranty expired 6 months ago. It appears I don't have any NG support options.
FURRYe38 wrote:I would make contact with NG support about this and see what your options are.
- tarzan_nojaneAug 03, 2020Star
Thanks for your reply. This is the command I have been trying:
[tftp -i 192.168.1.1 PUT RBR20-V2.1.4.16.img]
The "-i" switch specifies binary
TFTP [-i] host [GET | PUT] source [destination]
- -i Specifies binary image transfer mode (also called
octet). In binary image mode the file is moved
literally, byte by byte. Use this mode when
transferring binary files. - host Specifies the local or remote host.
- GET Transfers the file destination on the remote host to
the file source on the local host. - PUT Transfers the file source on the local host to
the file destination on the remote host.
source Specifies the file to transfer.
destination Specifies where to transfer the file.
