Sealine
May 29, 2020Tutor
Unwanted Remote Login To My LAN
I keep getting LAN Access from remote entries in the log on my Orbi RBR20. UPnP is dissabled. I have added some of the IP addresses to the blocked list on my NAS. What can I do/check please?
- May 30, 2020
You are, of course, correct. The NAS can be programmed to be sophisticated about who to admit (and who to reject). The Orbi is a more simpleminded gatekeeper. It is either "let people knock on this door" or "turn everybody away." Who gets admitted is up to whoever is running the door.
If you tell Orbi to allow connection to the NAS (or any other local resource), it is up to the resource to determine who should (and who should not) be granted access.
CrimpOn
May 30, 2020Guru - Experienced User
This is great, thanks. So 192.168.0.4 and 192.168.0.16 are devices connected to the Orbi LAN?
Mikey94025
May 30, 2020Hero
What is the device at 192.168.0.4? It looks like it is a website serving both HTTP (port 80) and HTTPS (port 443), as well as port 5000 and 5001.
If you don't have UPnP then did you explicitly setup port forwarding rules for these ports to this device so that it can be accessed by the outside internet? Any open port to the internet will be accessed/attacked and logged like this. It's usually safe as long as your device and the web software it's running keeps up with proper security patches and you're only serving web traffic.
