Sisyphus13
Oct 08, 2017Aspirant
Update firmware fail
Just purchased a RBK50. Current firmware on RBR50 and RBS50=1.8.0.6. Web orbilogin says no new firmware is available. Newly installed app on iPhone says "updated failed". Questions and statement: 1)...
- Oct 11, 2017
Upgraded firmware on RBR50 and RBS50 from 1.8.xx to 2.0.0.74 without incident. Orbi has been stable for two days and working well.
aaz
Oct 08, 2017Virtuoso
I had the same issue when I first got my Orbi from costco, it was 1.8.x.x probably same as yours - auto update failed so I did the manual update. I have not seen it auto update yet but others on this board say that it works.
I would just the the manual on your also - first satellites, and then the router.
Sisyphus13
Thanks for the replies. So the software may or may not work as designed? For a model that has been out for over a year? This does not bode well....
I may manually download the update at some point, but I am not encouraged by flakey/buggy software.
- st_shawOct 08, 2017Master
Mine has worked flawlessly since I bought it in January.
The old firmware did not auto update. That's a new feature. Your App is likely much newer than the old firmware on your Orbi.
Like I said. update to the latest firmware, then see if you have issues. Don't try to solve issues when you are running old firmware.
- Sisyphus13Oct 11, 2017Aspirant
