shankara
Mar 20, 2021Tutor
Update firmware via app or web?
Hello: I use the Orbi RBR50 router with the RBS50 satellite at my home here in India. The Orbi app on my iPhone says that I am using firmware version V2.3.5.30IN. The support web site says that the c...
shankara
Mar 23, 2021Tutor
My system is mostly OK. I was looking into firmware upgrades for possible security patches. I have not updated the firmware at all since I bought the Orbi in October 2019.
Mar 23, 2021Guru - Experienced User
What FW version do you have loaded currently?
It's best to update the RBS first then RBR lastly if you do.
V104 is latest. Just avoid using Traffic Meter feature. Seems to break Orbi operation recently.
I recommend that you factory reset and setup from scratch if you apply v104.
shankara wrote:My system is mostly OK. I was looking into firmware upgrades for possible security patches. I have not updated the firmware at all since I bought the Orbi in October 2019.
