sjh01
Oct 16, 2021Aspirant
update user name for my Orbi RBR40
My HP 7855 printer will not connect to my desktop's wifi network because my neighbor's network has the same network user name (admin). After running a network diagnostic I received a message saying t...
Oct 16, 2021Guru - Experienced User
I would wire connect a PC to your RBR in back then log into the RBRs web page using a web browser at 192.168.1.1 or orbilogin.net
If your nieghbor is using same SSID name then I would change the SSID name on yours to be something different so you don't get the two systems confused. Can be someting unique and or fun. You can keep same password that you used before.
sjh01
Oct 19, 2021Aspirant
Furrye38;
Thank you for your response. That partially worked; however when i got to the point of changing the name of my sim card, which currently is the factory setting admin, the only option provided is to change the password. There is no option to change the name. Where do I go to that?
Also, being new to the forum, I must confess that I find that using it is very confusing, and haven't been able to locate any instructions on using it. I did figure out how to ask a question, but responding to answers eludes me. The paragraph above was submitted previously but I haven't discovered what happened to it. Thanks...
- FURRYe38Oct 19, 2021Guru - Experienced User
I don't believe you can change the admin name to something else.
