jmbarbs
Apr 28, 2017Apprentice
Update V1.9.1.12 Netgear officially announcing 'Improvement in wireless connection Stability'
Just downloaded the latest release V1.9.1.12 and noticed in the official release notes from Netgear it states as fix 'Continious Improvement in wireless connection stability'..Dosent spefically makre...
Chadhetlet
Apr 28, 2017Guide
Can you link to the release notes? Not seeing it on the downloads page yet.
- jmbarbsApr 28, 2017Apprentice
Don't think i can now as it came up in a popup box when clicking hyperlink of the version number beore i clicked the update button. As you say its not been updated on the netgear downloads page. From previous versions this is usually updated on the website 24 hours after its available on the router
- tubastankApr 28, 2017Apprentice
Netgear,
When you release a new verion of firmware it would be nice to include release notes. I have nothing but issues with Parental Controls and devices keeping them persistently. I have to reboot the Orbi every couple of days. For example, I have "None" set up for my laptops (MacBook & Dell) but sometimes when I launch IPVanish to create a VPN connection, the VPN client errors. After I reboot the Orbi all is good for a couple days.
Anyone know if firmware version v1.9.1.12 includes fixes to the Parental Controls to keep them persistent....as it should be design?
- peteytestingApr 28, 2017Hero
where did you download this version from as the web site im looking at has only 1.8.0.6 version as the latest and checking the auto update its says no new firmware
