jmbarbs
Apr 28, 2017Apprentice
Update V1.9.1.12 Netgear officially announcing 'Improvement in wireless connection Stability'
Just downloaded the latest release V1.9.1.12 and noticed in the official release notes from Netgear it states as fix 'Continious Improvement in wireless connection stability'..Dosent spefically makre...
peteytesting
Apr 29, 2017Hero
yup correct location is the key here , too close and the clients will get confused , too far apart and the clients may disconnect in the middle
jmbarbs
Apr 29, 2017Apprentice
Been using latest version for 24 hours and still getting iOS disconnections. Lost patience now. Seriously considering google wifi now it's available in the UK. I'll put up with slower speed for greater reliability, as the orbi at present is unusable (for me)
- peteytestingApr 29, 2017Hero
jmbarbs wrote:Been using latest version for 24 hours and still getting iOS disconnections. Lost patience now. Seriously considering google wifi now it's available in the UK. I'll put up with slower speed for greater reliability, as the orbi at present is unusable (for me)
suggest you google a bit on google wifi as its having its own issues as well
http://www.techradar.com/news/google-wifi-is-facing-more-connection-problems
- Ts937kmApr 29, 2017Apprentice
I was just going to say. Got rid of google wifi after their first major outage. Now they just recently had a second. It has to check in all the time. If google is down so is your wifi. No thanks. Plus speeds were not good if you gave gigabit internet.
Have yiu you turned off the satellite and just tried the main router. Any disconnects?
or when it's all up. Try the free Netspot for mac/windows or telstra wi-if Maximiser for the iPad. And see if you have good coverage where you are.
try this. My ipads wifi was turning off when it slept. And this fixed that. Seems be an ongoing issues with iPads.
Restart the iPad after renewing your IP address or resetting the Wi-Fi network settings. To restart the iPad, hold down the "Sleep/Wake" button. When the red slider appears, slide it to turn off the device. Hold the "Sleep/Wake" button again to turn on the iPad.
Also if you are using WEP. Stop and switch to WPA. WEP can cause disconnects.
- rivetsApr 29, 2017Apprentice
Yeah, I'm seriously considering taking the Orbi back. Very annoying. Might look at the linksys or the new tp-link mesh. (Though I don't think that's in the UK yet)
rivets wrote:Yeah, I'm seriously considering taking the Orbi back. Very annoying. Might look at the linksys or the new tp-link mesh. (Though I don't think that's in the UK yet)
lol good luck with tp link , knowing these mesh systems pretty well now i would suggest you leave tp link well alone at least for the first 6 months
Yeah, though the tp-link kit which the Orbi is replacing was pretty solid. I may just go back to that. 4 SSIDs and all.
Need a a full wireless system though if I stay mesh - no way to run cables acceptably in the house. See how it goes moving the satellite up a floor. (Though that will be almost vertically above the router so less than 40ft most likely)
