jmbarbs
Apr 28, 2017Apprentice
Update V1.9.1.12 Netgear officially announcing 'Improvement in wireless connection Stability'
Just downloaded the latest release V1.9.1.12 and noticed in the official release notes from Netgear it states as fix 'Continious Improvement in wireless connection stability'..Dosent spefically makre...
rivets
Apr 29, 2017Apprentice
Yeah, though the tp-link kit which the Orbi is replacing was pretty solid. I may just go back to that. 4 SSIDs and all.
Need a a full wireless system though if I stay mesh - no way to run cables acceptably in the house. See how it goes moving the satellite up a floor. (Though that will be almost vertically above the router so less than 40ft most likely)
tubastank
Anyone figure out how to tell which sattelite your devices are now connected to? Prior to firmware v1.9.1.12 one could check by doing the following.
1. Log into your Orbi router
2. Under the BASIC tab, select ATTACHED DEVICES
3. Select a connected device and on the next screen put your mouse cursor in the name field and click ENTER on your keyboard.
The screen will refresh and will show you which sattelite your devices are connected to.
With firmware v1.9.1.12 this no longer works.
