jmbarbs
Apr 28, 2017Apprentice
Update V1.9.1.12 Netgear officially announcing 'Improvement in wireless connection Stability'
Just downloaded the latest release V1.9.1.12 and noticed in the official release notes from Netgear it states as fix 'Continious Improvement in wireless connection stability'..Dosent spefically makre...
tubastank
Apr 29, 2017Apprentice
Anyone figure out how to tell which sattelite your devices are now connected to? Prior to firmware v1.9.1.12 one could check by doing the following.
1. Log into your Orbi router
2. Under the BASIC tab, select ATTACHED DEVICES
3. Select a connected device and on the next screen put your mouse cursor in the name field and click ENTER on your keyboard.
The screen will refresh and will show you which sattelite your devices are connected to.
With firmware v1.9.1.12 this no longer works.
Ely
Apr 30, 2017Luminary
You can login into the satellite page and see which devices are connected to it, the rest are of course connected to the main unit, to login to the sat's page figure out what its IP address is by checking it out on the Orbi's attached devices page and then go open it with your browser, it will ask you for your Orbi's username/pass, once there click on "Attached Devices"
- tubastankApr 30, 2017Apprentice
Thanks for the workaround.
Netgear needs to get their act together. Nothing like having to jump through hoops when the information should be on the "Attached Devices" page. Just glad their not an automobile company. We'd be told we have to disconnect the battery terminal cables every time we shutoff the car otherwise the battery would drain.
