jmbarbs
Apr 28, 2017Apprentice
Update V1.9.1.12 Netgear officially announcing 'Improvement in wireless connection Stability'
Just downloaded the latest release V1.9.1.12 and noticed in the official release notes from Netgear it states as fix 'Continious Improvement in wireless connection stability'..Dosent spefically makre...
Ts937km
May 01, 2017Apprentice
I have been In IT for a long time 25+ qt the current T job. so yes I agree. Was just curious.
My air print seems stable as well.
And I don't use parental controls so no issues there.
And what is the -db loss between your router and satellite? Can you tell that?
I wonder if you turned the closest one off if it would help. Mine really cleared up when I got them about 40 ft apart on different levels. So both satellites are about 80 ft apart. And about 40 ft from the central router.
I left 2.4 and 5 at 100%
